Help! I have a coil Spring question
Old May 3, 2011 | 10:01 PM
imfrijole's Avatar
I have a 2006 G35 sedan sport class. The origional owner put lowering springs that are WAY TOO LOW. I cant go over the tinyest speed bump at .1 mph without scrapping.
Some guy is selling his origional 2006 G35 coupe springs on Craiglist. Will those fit my car? And what if any affect will they have? Lower, higher, softer ride, harder ride?
Old May 3, 2011 | 10:14 PM
Xet's Avatar
Xet
Coupe springs will lower it. And there is no way he put springs on that aren't coils or cut that are too low to get over speed bumps, they don't make springs that drop that low. Your shocks would die extremely fast
Old May 3, 2011 | 11:01 PM
EL-EE-ES's Avatar
Coupe springs will lower a sedan 1/2 inch from it's stock height
Old May 3, 2011 | 11:16 PM
4D05G35's Avatar
+1
Coupe springs will lower a sedan .5" over stock....well above scraping over speed humps.
Old May 4, 2011 | 04:09 PM
imfrijole's Avatar
Thanks for the reponces. I can deal with a half inch no problem. I'm too rough on the car to have it lowered as much as it is.
Will it affect the ride at all to switch to the coupes springs?
Old May 4, 2011 | 06:58 PM
4D05G35's Avatar
It depends on what springs you currently have. The springs you have now might have a higher spring rate than OEM. If thats the case then you will have a softer ride with OEM. Or it could be the other way around-----they may be softer then OEM.
reavensf
Sep 17, 2015 11:30 PM
HypedAndy
Aug 18, 2015 03:34 PM
linedr89
Aug 17, 2015 05:11 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
