Are caliper covers good at reducing brake dust?
Old Jun 2, 2011 | 08:21 AM
short it's Avatar
Hello.
I'm considering buying some caliper covers to cut down on brake dust.
- has anyone done this ? results ?
- any new squeaks, squeals, rattles ?
- do the calipers heat up more since they're not provided direct venting ?
thanks
Old Jun 6, 2011 | 02:56 PM
G force's Avatar
I dont have any experience, however I would personally look at alternative brake pads first, there are ones out there that produce less brake dust. Also, there are products you can put on your wheels that make it easier to clean off, almost like a wax.
Plus this way the wheels will look the same (I imagine dust covers not looking so great, almost make the rim look like a hubcap), and you dont have to worry about extra heat or vibrations with the brake pad route.
Old Jun 6, 2011 | 03:17 PM
4DGS's Avatar
1. No, they look pretty silly.
2. There should no be.
3. I suppose so, but not enough to make a difference.
I'm with the guy above, different pads are your best option. If you're dealing with severe dust then I'm assuming you're on stock pads which are notorious for heavy dust. Move to a higher performance pad like EBC green stuff or Hawk HPS.
Old Jun 6, 2011 | 03:40 PM
nogoodname's Avatar
Caliper covers are ugly, buy some low dust pads instead. done!
Old Jun 6, 2011 | 03:53 PM
prinny's Avatar
Hawk HPS do itt~! They aren't that pricey and the performance difference is HUGE.
Old Jun 6, 2011 | 03:58 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
"site:g35driver.com caliper covers"
laksjd84
Feb 28, 2026 01:58 PM
hdmark
Apr 29, 2019 04:31 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
mushu
Jul 15, 2015 03:55 PM
