coilover install was going good and then this happend HELP!
Old Jun 11, 2011 | 06:53 PM
infinitig35_6mt's Avatar
i have an issue i was installing my stance coilovers and now have an issue on the right rear side where the shock mounts up.
so the drivers side came off but took some effort, now the passengers side seemed to be rusted in there, i used penetrating fluid that didn't work, i marked each side of the bolt to make sure that i wasn't going to snap it. still it looked like it wasn't going to budge, so i used the heat trick, still nothing, then this happens i guess maybe the bushing got a little hot and the bolt is stuck in the metal sleeve,
QUESTION IS NOW can i replace this bushing or do i have to locate a complete arm,
please help if you can....
Old Jun 11, 2011 | 07:26 PM
DougJones's Avatar
The bushings can be replaced.
Old Jun 11, 2011 | 07:29 PM
thank you for your help. i will look more into it . i know whiteline makes an aftermarket but im going to see if i can get an oem..
Old Jun 11, 2011 | 08:10 PM
datbeans's Avatar
Same thing happened to me..
I replaced all the lca arm bushing and on one sideI used a very long cheater bar to get the bolt loose.
On the passenger side I had to borrow an electric impact wrench...
Try using some PB Blaster, works awesome. I also had to replace the bolt on the passenger side because the impact wrench rounded it pretty good.
Old Jun 11, 2011 | 11:54 PM
this one is the upper . where the shock mounts to.
i will have to call the dealer to see if its avaliable.
i have checked aftermarket, like moog or raybestos and kyb.
they only have a rear shock mount they call it but it looks completely different style its 2 pieces
and i cant find an aftermarket one that looks like mine.
Old Jun 11, 2011 | 11:57 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Whiteline makes an aftermarket rear upper control arm bushing
Old Jun 12, 2011 | 08:30 PM
MikeDG's Avatar
+1 on the impact wrench. It should break the bolt free easily. Some PB blaster will help too. For the bushings I'd go with ES or Whiteline.
Old Jun 15, 2011 | 04:24 AM
fixed and new bushing pressed in, took a little bit of time but now im just setting up the ride height,
Old Apr 3, 2012 | 10:27 AM
MJION's Avatar
How did you end up removing the bushing? AND What did you use to press the new bushing?
Currently dealing with the same issue and want to make sure I can remove and replace the bushing while still on the car.
Thanks
Old Apr 3, 2012 | 11:22 AM
i went to infiniti got a new bushing it was cheap. and i used a u joint tool for the removal and instillation!
Old Apr 3, 2012 | 03:59 PM
datbeans's Avatar
yay for a happy ending bro
Old Apr 3, 2012 | 04:29 PM
MJION's Avatar
did you use the u joint while on the car?
This one?
http://www.autozone.com/autozone/acc...er=557231_0_0_
Old Apr 3, 2012 | 07:49 PM
Datbeans thanks! Cars all done last summer
And yes that's the tool I used mine had a few more attachments but u can use sockets or what ever u have at home and no u don't have to remove the whole arm u can do it on there that's why I picked the ujoint tool, it's going to want to slide around a bit, find a socket that's the same as width as the new bushing but a tiny bit smaller so it doesint get stuck in the whole, the. Set up your u joint tool and press it out
Old Apr 7, 2012 | 11:02 PM
MJION's Avatar
Yep, used the air hammer and u joint.. easy as that.. thanks!
Jusseth
Sep 13, 2020 12:25 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
hdmark
Apr 29, 2019 04:31 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
