Swaybars
Old Jun 16, 2011 | 11:22 AM
Snakes' G's Avatar
Hollow or solid all that really matters is the stiffness. I've used hotchkis for about 2 years and I like them. I would get aftermarket endlinks though.
Old Jun 16, 2011 | 02:13 PM
BAUSauto's Avatar
Hollow bar thats welded.. versus sold one piece bar...
I'm just saying if you have an 05+ Sport G35 (6MT or Factory Sport Package) you're not benefiting anything by changing your front sway to any of the hollow sway bars.
Originally Posted by Xet
Are you at all referencing between different stiffness settings? Or is this a comparison on the lowest or low/mid levels?
They did tests with the sways bolted at the stiffest setting
Old Jun 16, 2011 | 02:20 PM
Deepdiver's Avatar
^ No difference if (on the hollow bar) you set it on the med hole. But everything does get noticeably stiffer/flatter if you set the end links in the hard hole.
NailBomb
Oct 28, 2015 07:53 AM
SIKKI
Steering & Suspension
Sep 16, 2015 01:14 AM
dorkstar
Sep 16, 2015 01:02 AM
