Uneven pad wear
Old Jun 25, 2011 | 05:31 PM
All G'd Up's Avatar
Uneven pad wear
I changed my rear brake pads bc there was a grinding noise when I would brake coming from the rear. When I took the rear pads off the inner pad on each side was worn to the metal but the outer pad on each side had a good amount of pad left (30-40%). Is this normal on the brembo pads? I'm pretty sure the pads were original from the factory as I only have 39k miles (I bought the car w/20k miles on it).
Thanks
Old Jun 27, 2011 | 07:43 PM
Mustang5L5's Avatar
Are the Brembo's floating or non-floating? (i beleive non)
Usually uneven pad wear is due to some part of the caliper seizing up and sticking. On floating type calipers, its usually the slide pins. It could also be a piston.
You should inspect the calipers completely and check for anything that looks like it's sticking.
Old Jun 27, 2011 | 08:32 PM
All G'd Up's Avatar
both pistons seem to be working fine. I'm not sure what you mean by floating/non-floating... the pads do just sit between the pistons and rotor and are held in by pins at the top, they were real easy to replace.
Old Jun 30, 2011 | 09:50 PM
All G'd Up's Avatar
Any other suggestions....
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Jeff T
Sep 30, 2015 02:00 PM
