Please Help with WOBBLING/shaking rear wheel, thanks!
Old Jul 19, 2011 | 01:44 PM
smokedhen's Avatar
Hi everyone,
It's been awhile since I've been on.
When I'm driving around 30-40 mph , my friend tells me that the rear driver's side wheel is wobbling/shaking. It is fine rolling or going at lower speeds.
could it be the wheel bearing?
what might it be? just wanted some thoughts before I get raped by the mechanics' prices.
thank you!
04 g35 coupe
~56000 miles
Old Jul 19, 2011 | 01:46 PM
alexm's Avatar
Maybe a bent wheel?
Old Jul 19, 2011 | 01:55 PM
Deezflip's Avatar
+1 bent wheel or...
have you modified anything on the car lately? suspension? lowered? toe alignment can be completely off when lowered causing it to "whale" out
Old Jul 19, 2011 | 09:26 PM
smokedhen's Avatar
thanks for the suggestions.
no modifications.
do u take off the wheel and just inspect to see if it's bent?
Originally Posted by alexm
Maybe a bent wheel?
Originally Posted by Deezflip
+1 bent wheel or...
Old Jul 20, 2011 | 02:06 PM
acchen's Avatar
You can usually see if its bent from checking on the lip of the rim. You should take it off and check the inside lip too just in case...
rezendvous420
May 31, 2020 01:26 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
