ABS troubles
Old Jul 25, 2011 | 09:47 PM
looke83's Avatar
ABS troubles
I'm having a problem with my 2003 G35 when going through a right hand corner. If im coasting through the corner with no throttle and no braking the slip light will flash and then the front right brake will grab for a split second a couple times.
I was told that this could be caused by the wheel bearing starting to go bad.. so i changed it and had no luck with helping my problem.
Anyone have any suggestions ?!? Thanks
Old Aug 2, 2011 | 06:12 AM
Mellowman's Avatar
Wheel speed sensor? Get it scanned while taking it for a drive and see what it picks up.
Thebaws11
Jul 2, 2021 11:36 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Thebaws11
Nov 30, 2016 12:54 PM
dseet
Oct 11, 2015 12:40 AM
