Rear suspension squeak
Old Aug 11, 2011 | 10:05 AM
bsowhat1's Avatar
Ever since installing Tein H tech 350z spring, Tokico struts, toe bolts and camber arms, the rear passenger suspension squeaks terribly. Very audible inside the cabin. I greased the spring, spring mounts and rubber isolators but it didn't help. Short of disassembling the entire rear suspension, anyone have any suggestions?
Old Aug 11, 2011 | 12:27 PM
brandon1978's Avatar
I'd bet on the shocks. Recheck the torque on each of the upper bolts. Make sure the rubber cover is completely pressed on; I've noticed increased noise if it is even a little bit off. If that doesn't work, remove the shocks, drive around the block, and see if the noise went away.
Old Aug 12, 2011 | 09:18 PM
bsowhat1's Avatar
Is the shock noise a squeak or rattle? Seems like loose bolts would cause rattling.
Old Sep 10, 2011 | 10:03 PM
bsowhat1's Avatar
The squeak is not the shock. I suspect it is a bushing. Anyone have any thoughts?
rezendvous420
May 31, 2020 01:26 PM
tiguy99
Mar 1, 2016 11:42 AM
si_driver
Aug 11, 2015 07:08 AM
wuppiedog
Aug 7, 2015 11:16 AM
ddietz97
Jul 26, 2015 06:16 PM
