Harsh ride from coils
Hey everyone I just installed some coilovers on my car.. (NON TRUE)
I just have a question about how it rides. The car is really bouncy... not bouncy as in smooth lincoln town car bounce.. but bouncy like a go kart bounce! It harsh and it hurts my back.. I dont know what is causing it bc it wasnt like that when it was first installed and lowered.. but since the car was too low for my taste, I raised it up from the shocks and left the damper (10clicks out of 18clicks) and preload on the springs all the same as it was when I first installed it on the car and lowered. Didnt mess with it when I had it first installed. But since I raised it, the car rides all stiff and harsh..
What should I do? Mess with the preload or the damper?
Why would the height adjusting cause the harshness? I dont understand? I left the preload and damping all the same as it was right when I first installed it too low. Raising it up made it harsh... when it was low, it felt smooth like stock.
i believe it 10k for the front and 7k for the rear.
You might try this first before adjusting the dampening setting.
Oh okay. Yeah the fronts ride fine. Also would turning the dampening to the right make it more harsh or more smooth?
10k 7k wow!!! My new set up is going to b 16k 8k.... I'm going to b running low tho. My oold coils I'm going to b selling are stance lx and my ride was perfect either way I set them... I never had the issue w/it being to harsh. I would do what dude said tho set the rear ride height first.
with the MDU's to the right is soft and to the left is stiffer..and i dont see how changing height from shock body caused this but i have these and had to convert them to true style coilover in the rear cause i was having the "go kart bounciness' in the rear and i didnt change the damper or height..just made them true style with same dampening and bam..night and day!! no more bounce..smooth sailing even with a 3 inch drop! im on like 8 rear and 6 or 7 front and im satisfied..TRUE style is the way to go with the MDU's from most peoples opinions with these..unless you want your ride SLAMMED then you have to go oem style
i thought going true makes it lower? so non true is less lower.
BTW i need to know how about going to do this??
from what ive seen most coilovers get stiffer to the right and softer to the left but the MDUs are opposite..18 right clicks is full soft...18 left clicks is full stiff..i have my fronts like 11 or 12 clicks to the right and rears 10 clicks to the right and ride is close to stock.
and going true doesnt get you as low as OEM style because the shock can only be compressed so much before your riding on springs...if you twist the shock to make it shorter and it will eventually stop where as in OEM style you can keep going due to your springs arent combined with the shock..
Search setting preload or droop, usually it is set your spring height and then jack it up ~10mm and then adjust the shock to that height to bolt up.
If I adjust up or down (shock body) doesnt that change the height of the car also?
What would be the ideal height of the shock body to the preload? I guess what Im trying to say is how would I know if the shock body is matched up with the preload?
I am such a noob to this..
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
