BC Racing Rear Coilover Adjustment
Old Aug 14, 2011 | 04:55 AM
thn116's Avatar
So I just installed my BC racing coilovers this past weekend and was trying to adjust the ride height. The front is where I want them but the rear is a issue.
My question is.....
1. Is there any correction for the driver side rear that sits lower than the passenger side? I read that it is often lower than the passenger side rear. I've maxed out the driver side threads on the spring and and damper and its about a 1/4 inch lower compared from the passenger side.
2. When trying to raise the rear to a more comfortable height, the rear coilovers and springs seem be maxed out with the threads on them. I have a finger gap space between my tire and my rear fender. I'm running a 18x9.5 +20 with a 275/40/18 tire. I don't mind being low but I expected a little more clearance if I wanted to. In addition, if the coilovers settle any futher I'll be in trouble.
Old Aug 14, 2011 | 06:05 AM
Xet's Avatar
Xet
My question is.....
1. Is there any correction for the driver side rear? I read that it is often lower than the passenger side rear.
Um adjust the height? You are running freaking coilovers wtf...
2. When trying to raise the rear to a more comfortable height, the coilovers and springs seem be maxed out with the threads on them. I have a finger gap space between my tire and my rear fender. I'm running a 18x9.5 +20 with a 275/40/18 tire. I don't mind being low but I expected a little more clearance if I wanted to.
Take a picture of how you're spring is setup, but one finger gap is pretty decent. Much higher and you are running in some of the just springs territory.
just get the pics so we can confirm if it is all setup right.
Old Aug 14, 2011 | 11:24 AM
Jaygotboost's Avatar
Lol
Old Aug 14, 2011 | 02:36 PM
thn116's Avatar
I'll be sure to post pictures as soon as I can.
I would adjust the height on the driver side rear but like I said before I've already started to max out on the threads on the spring and damper already. I only read one thread here that said that is normal. Just looking for another opinion.
Old Aug 14, 2011 | 05:20 PM
Massios's Avatar
Driver side lower is normal, mine is/was 1/4in.
I had to raise the drivers side quite a bit to even it out. For the rear it can be more difficult if you have the thread locks out.
Old Aug 14, 2011 | 05:55 PM
thn116's Avatar
I guess there is no way to correct that problem?
Old Aug 17, 2011 | 08:40 PM
acr's Avatar
acr
My BCs came with a gold spacer (~20mm) for the rear springs. These allow me to raise the car to stock height (or above, if one wanted to do that).
Old Aug 18, 2011 | 09:42 AM
thn116's Avatar
But you have the X. Not sure If those gold spacers are used for the non X's.
Old Aug 25, 2011 | 09:55 PM
thn116's Avatar
I talked to a BC rep today and they said it seems like a spring issue. I need to buy another of set of rear springs that comes out to 230mm which should help. But I'm going to wait it out and have everything setup before I decide to get the new ones. I'm trying to have a finger gap clearance all around. The car is purely a project now and won't see a snowy road so it may not be worth it. I just like having the ability to raise and lower it if I ever need to. Ideas?
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
