Megan Street Series Coilover
Old Sep 3, 2011 | 12:20 AM
G35sedan03's Avatar
they do look sweet, enjoy!!
Old Sep 3, 2011 | 12:31 AM
SuperCleanG's Avatar
Throw some spacers on that b!tch.. But if you dont will you need to roll the fenders.. Thats a sick drop.. Is it a stiff or soft set up. Trying to decide with to go with myself but I hate when I hit a bump now with my tein Htech' and I can really feel it.
Old Sep 3, 2011 | 01:45 AM
alpa_chino's Avatar
yea thats next on the list of many....
fender roll
spacers
camber kit
sway bars
front strut bar
i set it to 17 from 1-32 so right in the middle. its fine for me. the streets here suck so when i go over all these pot holes n other mess they made of these streets i feel it but its not too bad. when the streets are nice though its a smooth ride
Old Sep 3, 2011 | 01:46 AM
alpa_chino's Avatar
i think now ive had them almost a month the fronts a little lower then the rear...but when i do the rest of this set up ill take a better look at it
Old Sep 4, 2011 | 11:53 AM
G35sedan03's Avatar
if i were you, i would do the sway bars next. you will feel a huge difference that will compliment your current spring settings. BTW what are the spring rates for those megans?
Old Sep 4, 2011 | 12:01 PM
G35sedan03's Avatar
Never mind, i gor them off the website. this will help who is interested in them.
SPECIFICATIONS & FEATURES:
APPLICATION:
Nissan 350Z/Infiniti G35 2003-2007
SPRING RATES:
F: 62mm ID; 200mm length; 10 kg/mm
R: 62mm ID; 200mm length; 8 kg/mm
DAMPER SPECS:
F: 135mm stroke; 270mm length; A2 valving code
R: 135mm stroke; 240mm length; A1 valving code
- 32 Levels of Damper Force Adjustment
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
Old Sep 4, 2011 | 12:10 PM
alpa_chino's Avatar
^ lol there u go.
Yea MD swaybars and GTspec strut bar are next. I think camber kit will be later down. Spacers after I get fenders rolled down the line.
I got mine set at 17.
Old Sep 4, 2011 | 02:29 PM
G35sedan03's Avatar
you would want to do the camber kit following the sway bar install as soon as you can. the neg camber at that point, the colis, the drop and the sways, will add considerable amount of neg camber which will eat your tires.
Old Sep 4, 2011 | 07:48 PM
alpa_chino's Avatar
Damn even more money. I try n space stuff out so it won't b ramen n water kind of month lol. But once you touch one thing here comes the next ya gotta do. Never stops...it's like crack!!
Old Sep 5, 2011 | 12:08 AM
G35sedan03's Avatar
that's how the modding bug goes, but after you install your ciolover kit, not sure if you are getting an alignment done after that, you might not be too far off depending on the drop you go with.
Old Sep 5, 2011 | 12:39 AM
alpa_chino's Avatar
havent gotten one yet...its actually been riding fine. waiting till after the rest of the stuff on the suspension then i will need it for sure...dont think my drop is that low like some
Old Dec 3, 2011 | 12:58 AM
dyzfoo's Avatar
How's the ride so far till today? Still riding good? Close to stock?
Old Dec 3, 2011 | 01:42 AM
alpa_chino's Avatar
Yea ride still is good. Only thing I think I set my fronts a lil too low and I could drop the back a little bit. I rub on the fender well a lot up front but I'm sure if I raise it up a bit will fix it. Now everything has had time to settle I should readjust the hight but I'm lazy. Maybe one these days.
Old Dec 3, 2011 | 03:48 PM
dyzfoo's Avatar
Nice, maybe roll your front fenders? If sparks don't fly, your car is too high..hahaha
Old Dec 3, 2011 | 04:07 PM
  #30
alpa_chino's Avatar
Lol yea. I think I just need to bring the front up 1/4 inch n bring the rear down maybe 1/2 inch. Maybe I'll get to it this month. Dunno...wish it had like the tein and edfc n could do it by pressing a button
