Rear clicking
Old Sep 3, 2011 | 06:02 PM
acchen's Avatar
Rear clicking
Hi everyone, so I got my 2003 G used a couple months ago, and its been slammed on coils all of its life. I noticed that the rear starting clicking, I read that it might be the rear axle. The best way to describe the sound would be simply light popping of the bubbles in bubble wrap. Happens more evidently when I am at very low speeds, starting from a stop or coming to a stop.
Is this caused by my car being too low? And do you guys think that this sound is actually from the rear axle clicking? I want to diagnose what the sound actually is and how much the fix will be. Thanks.
Alvin
Old Sep 4, 2011 | 05:18 AM
Blue Dream's Avatar
I drove ttrank's car solo
It does sound like the axle click. Is it a light, metalic clicking? If so it's a pretty easy fix if you can turn a wrench. It took me a couple of hours and a $6 tube of synthetic grease to do both sides. Better than the $400 the stealership wanted.
Old Sep 6, 2011 | 10:28 AM
Mobydick's Avatar
I have the same issue with mine. Is yours on both sides? Mine only comes from the passenger rear.
Old Sep 6, 2011 | 02:05 PM
viceversa's Avatar
http://my350z.com/forum/engine-drive...rear-axle.html
Old Sep 6, 2011 | 04:26 PM
acchen's Avatar
I think mine's only on the driver side I hear a very faint clicking, but the entire rear I'll hear the popping bubblewrap sound...
Old Sep 6, 2011 | 04:31 PM
Blue Dream's Avatar
The other thing I didn't mention that will cause the clicking is a loose axle nut. Pull your wheels and you'll see it in the hub. IIRC it's a 32mm nut and it's torqued to 177 lb/ft. You might want to check this first before you start pulling axles and re-greasing them.
Old Sep 6, 2011 | 05:05 PM
GeeWillikers's Avatar
Walking The Fine Line...
Yep - sounds like axle click. I had it and the dealer took care of it under warranty. I primarily got mine when shifting from P to R the first time of the day. Mine wasn't always consistent but it was there more often than not.
Very annoying is all I'll say.. If I hadn't been under warranty I would have done it myself as Blue Dream suggests - it isn't that complicated to do.
Old Sep 6, 2011 | 05:28 PM
acchen's Avatar
Thanks for all the advice guys, I'll check the loose axle nut first and go from there. The click is there a majority of the time, so I might really have a problem here.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
mtlruss
Dec 20, 2015 01:51 PM
Frostbite91
Aug 20, 2015 07:20 PM
dimentio1
Aug 16, 2015 11:47 AM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
