Bad Brake Pads?
Old Sep 6, 2011 | 06:48 PM
pigpen infiniti's Avatar
Bad Brake Pads?
Hey G-folks before I buy new brake pads I wanted to make sure that is the problem I am having. My right rear brake has been screeching every time I slow down. I opened the caliper to take a look and found that one of the pads is worn at an angle. Im guessing that is not normal. Does that have something to do with the piston not working properly or just a bad brake pad install? Any ideas? I am planning on purchasing new pads from R1concepts. Any suggestions on a pad?
Old Sep 6, 2011 | 07:35 PM
MikeERideWNC's Avatar
Sounds like it was not installed flat to the piston.
The pads were quite difficult to line up in the caliper.
I am using the Car Quest pads.
They work just fine and are affordable.
The squeel is probably the chatter clip making contact with the rotor to warn you.
Old Sep 7, 2011 | 06:22 AM
Blue Dream's Avatar
I drove ttrank's car solo
You might have a frozen caliper or piston. That could explain the wear.
Old Sep 7, 2011 | 04:21 PM
Mustang5L5's Avatar
What he said
Common for the pistons and/or guide pins to seize. Def inspect and grease the pins befor eputting new pads in or you'll have the same issue
Old Sep 7, 2011 | 05:25 PM
Alright will do! Thanks for the help. I am thinking of getting the posi quiet pads or stop tech. Would you consider either of those good pads?
Jiggerjuice
Oct 5, 2015 02:33 PM
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
