Help me with squeaking front end
Old Sep 10, 2011 | 01:42 PM
Snakes' G's Avatar
I have been having a squeaking coming from my front end for a month now and I can't find the source. It's coming from the drivers side. I replaced my whole compression rod and everything has lots of lube on it. My coilovers have about 12k on them so I don't think it's them. It sounds like a bunch of birds are following me around and is driving me nuts. Only occurs when hitting little bumps. I checked endlinks and sway bar bushings. I'm thinking maybe it's the ball joint for the lca? It's much worse when it's very humid outside. Anyone have other suggestions? Thanks
Old Aug 9, 2012 | 09:47 AM
Snakes' G's Avatar
Does anyone have any suggestions? The noise has progressed to what sounded like a pulley issue. It chirps when i hit bumps and also will squeak/squeal when moderate throttle is applied or when shifting while accelerating briskly. I replaced the power steering pump, alternator and idler pulley. Noise is still present when A/C belt is removed. I can't replicated the noise while revving while parked. It also gets worse when the car is warmed up. I'm about ready to give up and take it to a shop.
tiguy99
Mar 1, 2016 11:42 AM
wuppiedog
Aug 7, 2015 11:16 AM
ddietz97
Jul 26, 2015 06:16 PM
newg37
Jul 26, 2015 09:32 AM
