problem with removing front wheel bearing...
Old Sep 26, 2011 | 10:56 PM
Cooldude04's Avatar
Hi all
I've tried to replace my front wheel hub over the weekend. I followed this instruction..
http://my350z.com/forum/brakes-and-s...nt-how-to.html
I removed 2 bolts that holds the caliper, 4 bolts that hold the wheel bearing and additional speed sensor but couldn't get the wheel bearing hub off.. and I couldn't remove the brake shield either... Has anyone removed the wheel bearing before? any help appreciated...
Old Sep 27, 2011 | 01:26 AM
obender66's Avatar
Just hammer it out. It is stuck/rusted in
Old Sep 27, 2011 | 06:00 PM
Cooldude04's Avatar
There was a plastic hub cover from the inside of the wheel hub, it's where the speed sensor is, should I remove it first then hammer it out...?? i'm afraid i'm gonna damage the hub cover.
Old Sep 27, 2011 | 06:25 PM
obender66's Avatar
Oh, no- do not touch that plastic part at all. Hammer outside of the bearing, where the studs are. Turning the steering wheel will give you more space to work. Brake shield can be slightly bent to be out of the way.
Old Sep 27, 2011 | 08:54 PM
Cooldude04's Avatar
oh got it. I'll try it tomorrow.. thanks
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
mike730
Jan 12, 2018 04:25 PM
rping
Jul 26, 2015 09:53 PM
TheefrshstVQ
Jul 26, 2015 09:37 PM
