Compression Rod Ball Joint keeps going bad?
Old Sep 30, 2011 | 12:18 AM
nrmskate's Avatar
Okay, so long story short. Bought my 04' G35 with a clunk in the front end, asses the problem by replacing what I thought was the Compression Rod bushing. Wasn't the problem. Look at the problem even further and come to find out that it's the balljoint on the compression rod. So at this point I have to replace the whole rod. So I replace the rod and literally 2 days after I install it, it goes bad again.. So I just bought another arm from the dealership. I kinda would like to know if any of you guys would know what is causing them to go bad before I put the new arm on. Car has perfect alignment. Has two different tires with close to the same amount of tread on the front. Shakes a little bit on the highway with or without the new arm. Basically, I don't want to have to buy a new arm every two days, so I would like to know if anyone had any insight?
Thanks much!
Old Sep 30, 2011 | 05:12 AM
davidchoi425's Avatar
you might want to try wheel balancing and/or check to make sure your rotor surface is even and not warped. Also you may want to try SPL FKS front compression rod bushings (https://www.splparts.com/store/produ...hp?pid272.html). hope this helps.
Old Sep 30, 2011 | 05:25 AM
chink-ah-saur's Avatar
Bump
Old Sep 30, 2011 | 08:01 PM
nrmskate's Avatar
I went to go get new tires today to come and find out that I have two front bent rims.. Great
On a side note, the bushings are perfect and not torn at all. Rotors are good and not warped.
It shakes badly on the highway.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Vqalexisz
Oct 14, 2015 12:48 AM
reaper76
Sep 20, 2015 11:59 AM
Moskvitch
Sep 14, 2015 10:15 AM
junon
Sep 5, 2015 10:40 PM
