NEED HELP! in the middle of suspension upgrade
Old Sep 30, 2011 | 01:07 AM
6mt2nr88's Avatar
so I am currently installing a set of KW V3 coilovers and SPL front arms rear camber arms and rear toe arms on my G35.
I have 2 problems. first the bolts on the front shock mounts to remove them from the shock are so rusty. i tried PB blaster and everything else I can think of. I think I'm just going to buy a new set from infiniti tomorrow.
the main problem though is with installing the Toe rods in the rear. they r wedged in and i cnat get them out (see pictures below) it was so close I couldn't even get a socket on the bolt I had to use a wrench. does anybody know how to get these off? SPL doesnt have any instructions posted. I tried searching on the forum and couldn't find anything
thanks in advance guys.
Old Sep 30, 2011 | 01:41 AM
blAk mAx's Avatar
did this on a friends car back in april..i think we may have pushed the suspension down and pulled out (i dont remember what exactly)..or used a hammer... i know when putting it back in we put the top part in 1st
Old Oct 3, 2011 | 09:18 PM
SilvrCoupe's Avatar
if you really cant get it unstuck and are replacing the arm anyways... cutoff wheels are a man's best friend,
or a dremel 4000 is what i used, tooka little longer, but more accurate!!
Old Oct 3, 2011 | 10:29 PM
6mt2nr88's Avatar
yea i just had to drop the suspension. and it came free
nissandrifter32
Dec 22, 2015 04:28 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
