Do i have to change pads when replacing rotors?
Old Oct 7, 2011 | 03:12 PM
Cheech's Avatar
have hawks hps on the brembos on my 04 coupe and still have soem life do i need to change it when i change my rotors soon? thanks
Old Oct 7, 2011 | 03:18 PM
Texasscout's Avatar
No, you don't HAVE to, but if you want even wear on your expensive rotors, buy some pads or if they are new(ish), find someone with a table sander and resurface them flat.
Old Oct 7, 2011 | 03:38 PM
Cheech's Avatar
Pad recommendation?
I have haks hps which is ok but i liek how it slow in dust... recommend any pads with low dust?
Old Oct 8, 2011 | 08:45 AM
Texasscout's Avatar
I'm gonna let the others here make a recomendation for that. I have an 05' and I LOVE my stock pads. They grip in the wet and don't dust. I do know that 04' and older had a problem with the stock pads dusting very bad. I had the hawk hps also, when it was warm and dry, there was nothing better. But when it was cold and wet, it was like no brakes at all for a second or two. I got rid of them fast.
Old Oct 8, 2011 | 10:52 PM
gary c's Avatar
You don't need to replace the pads when replacing rotors but I would. It's just a good idea when replacing rotors to include new HAWK HP pads so it's all new and works better....don't forget the bed in process for your new pads!!
Gary
Old Oct 10, 2011 | 04:59 PM
Ray@OCInfiniti's Avatar
it's not required, but it's best to. During bed in processes, you're actually transferring slight amounts of pad material to the rotors, and both the pads and rotors will slightly re-shape to each other. This is the normal physics of breaks. Once the old rotors are taken off, the pad surface of the old pads is now smoothed or glazed to match the old rotors, and may not transfer material to the new rotors as well as they would if the pads were new.
Any further questions, just pm me
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
