New Whiteline compression rod bushings
Old Oct 20, 2016 | 07:02 PM
Genthusiast35's Avatar
Where is the rear spring bucket bushing?
Old Oct 28, 2016 | 10:25 PM
Swaglife81's Avatar
Originally Posted by ScraggleRock
If you go to conceptzperformance.com you can buy all the bushings separately. The ones you really want (aka NEED for the G) include:
Compression rod bushings
Lower control arm bushings (inside and outside)
Rear spring bucket bushings
Those are the MUSTS for this car. Other ones that aren't necessary, but are noticeable are: front upper control arm bushings and the differential bushing. The differential bushing drastically changes ride characteristics tho, so you really gotta want that "track car on the street" feel.
While on the topic. I noticed today one of my lower ball joints is trashed. It's fully busted and the passenger side is meh. My car has 201K on it and I just bought it 1k miles ago. To do the ball joints I'm gonna have to get some bigger tools and rent a press. The rear looks good from what I can see. What else should I look for up front. There is only so much one can see visibly. Not sure if it's better to get new transverse links, upper control arms , etc with poly bushings in them or just replace all the bushings. I don't want to spend a ton of money on these tools over getting a shop to install everything. I will do springs this week also. So while Im doing springs and lower ball joints I might as well replace what I can while I'm in there. I have no wires noises and car rides fine. Front tires do have excessive outside wear on them however.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AL8782
Oct 3, 2015 10:26 AM
