Stripped Screw
Old Nov 23, 2011 | 11:08 AM
sindaddy's Avatar
Stripped Screw
I've stripped the screws on the upper housing using a torque wrench, is the housing replaceable? or should i replace the entire struts?
Old Nov 23, 2011 | 11:17 AM
redpearl99's Avatar
why don't you just remove the stripped screws
Old Nov 23, 2011 | 04:25 PM
dofu's Avatar
20 Year Member
You can pick up a kit to remove stripped bolts or nuts, Craftsman makes a great kit for stripped bolts that can be purchased at Sears.
With that, you can remove the stripped bolt, and you can take that bolt to OSH, Lowes, Home Depot, or any other hardware store to find a replacement.
Stripped screws are a bit different, a bit more complicated as those usually need to be drilled out. But there are ways to get those out as well.
Old Nov 23, 2011 | 04:34 PM
JOKER's Avatar
CLUB MODERATOR
there are reverse drill bits for the screws that can get the screws out for you in a jiffy.
Old Nov 23, 2011 | 05:50 PM
redpearl99's Avatar
no need, if the screw isnt torqued down hard then just cut a notch into it and use a flat head screwdriver
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
jbmw002
Sep 10, 2015 12:54 AM
