Stance Coilover Install
Old Dec 30, 2011 | 02:08 AM
_FrankStarks_'s Avatar
I'm getting ready to install my Stance Coils/SPC Kits tomorrow. Any pointers I should know about ie Locktite for the mounting bolts etc etc. Any input would be appreciated.
Old Dec 30, 2011 | 02:15 AM
redpearl99's Avatar
there's nothing really special you need to know about. You can use locktite but use the blue and not the red
Old Dec 30, 2011 | 02:25 AM
DrewDrew's Avatar
I installed my Stance coils and SPC arms by myself. Easy install on both.
Nothing really major. Take your time, and be patient. The only slight trouble I had was jacking the suspension in order to take the end links off the lower control arm on the front suspension. It's a very slight opening to knock them out freely. Double check your work. Don't forget the small things, like the brake lines or the nut. Be careful when you release the stock a-arm or the SPC ones if/when you adjust them. Mine fell and chipped my fender paint off. I might recommend masking off your fender for a couple inches, I found my coils and stock suspension rubbing as I tried to maneuver them out/in.
Make sure you have blocks when you finally release and lower the car down - your jack might not be able to get out from underneath the car because of it being lower.
Old Dec 30, 2011 | 02:27 AM
ShanesG's Avatar
Only thing is make sure when to do the fronts you have the entire front up on stands.
Remove the sway bolt from lower control arm.
Rears are easy, just use a jack to get the spring bucket in place( unless you have the true setup)
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
itztwinki3
Oct 5, 2015 11:29 AM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
