Compression rod ball joint bushing
Old Jan 31, 2012 | 08:19 AM
g35SedanSC's Avatar
A quick question,can you change the ball joints on the compression rod,or you have to buy the whole new part?as i mean compression rod,thank you.
Old Jan 31, 2012 | 10:15 AM
Invalid_User's Avatar
Originally Posted by Phil@GRUBBS
you know, it's funny, here at the dealership we've heard it called everything, rear lower control arm, that boomerang shapped thingy, the curved arm.... we usually can figure out what they want by then
and the bushing is actually sold seperately from Nissan 54570-AC70A
The ball joint??
sign me up if so
Old Jan 31, 2012 | 10:21 AM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
The compression rod bushing, yes, you can get it seperately from Nissan, the ball joint, no, might get it aftermarket somewhere, but through nissan it's not seperate from the compression rod
Old Feb 9, 2012 | 02:33 AM
thekatocat's Avatar
Sorry to jump in on the thread, but I'm a total newbie and want to resolve this issue as least painful as possible given that I plan to sell in one year.
I got excessive inner tire wear on the front right tire of my '03 coupe, the tire center guys showed me what appeared to be the bushings to be shot on both sides and a leaky front right strut. From what I gather, I do not need to replace the forward lower control arm but, just in theory, the bushings on the compression rod. Since I want to minimize the expense and don't have access to a press to change out the bushings.
I'm just planning change out the compression rod for now. Can some one confirm that thats all I should change out considering I haven't noticed the any performance issue (leave strut or front lower control arm as is)?
Finally I've seen varying prices for the compression rod ranging from 200+ per rod at the dealership, avg price seems to be around $175 at the Infiniti parts online sites/variations of such. I found the cheapest to be at rockauto.com for around $90. Description matches but I'm a little skeptical about such a price difference. part numbers seem to match, but maybe they don't include bushings?
http://www.rockauto.com/catalog/rafr...971000-3213085
Can anyone give me some insight as to if 1) I'm on the right track towards resolving my excessive inner tire wear issue. 2) $90 is a reasonable online price for the compression rod incl. bushing?
Old Feb 10, 2012 | 08:52 PM
TITANG9's Avatar
G35 RWD AUTO
[quotehttp://www.rockauto.com/catalog/rafr...971000-3213085[/quote]
Nothing for Sedans???
Old Feb 11, 2012 | 03:48 PM
g35nit's Avatar
is mevotech a decent compression rod brand?
Originally Posted by redpearl99
This is a lower control arm on the front suspension
This is a compression rod
Do you see the difference
Is mevotech a decent compression rod brand? i need one asap and found the cheapest on partsgeek.com. if not what brand would you recommend? thx
Old Feb 11, 2012 | 06:36 PM
kpowe1's Avatar
Ok quick question about compression rods, I have an 03 sedan that needs compression rods do I have to buy a new set of rods or just bushings
Old Feb 11, 2012 | 07:07 PM
TITANG9's Avatar
G35 RWD AUTO
If you can see in the picture above, the compression rod, it has a ball joint. If the ball joint is in good condition without any clunky sound and you can assess this, just replace the bushing. All really depends on this: How many miles are on the G and for how long you want to keep it?
Old Feb 11, 2012 | 07:17 PM
kpowe1's Avatar
Thanks
Old Jul 22, 2012 | 05:01 PM
frankie03G's Avatar
Anyone using Mevotech Aftermarket Parts??
With 189,000 miles on my 2003 G35 Sedan (non-sport) and counting, I need to replace my compression arm bushings/ball joints because they are shot. I always felt OEM parts were better, but after reading much negative publicity on the OEM compression arm bushings and ball joints, I wondered if going aftermarket would be smarter? Not looking for performance gains, just want the stock feel. I see that Mevotech makes compression arms (they call them control arms, whatever) Part # MS30163 Left; MS30164 Right. Got this info from Rock Auto Parts Website. Anyone using these and if so, how are they holding up?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AL8782
Oct 3, 2015 10:26 AM
Jeff T
Sep 30, 2015 02:00 PM
