Sway Bar links and Rotor question,
Old Jan 9, 2012 | 01:25 AM
g35SedanSC's Avatar
Question Sway Bar links and Rotor question,
Hi,
1 Q. my sway bar link is making a noise like there is no tomorrow every time the suspension is flexing(stock everything)
1 should i go to the dealer and get all the parts?
2 should i just get OEM replacements online?
3 or a brand name replacement?
when i asked the dealer about changing them he named almost every component there is for the suspension,which i think he is trying to rip me off.
so could you guys point me in the right direction to get rid of the noise,thank you.
2 Q.
when i apply the brake the feedback from the brake peddle is like a wave,when i put the car in the air(on the lift) and try to spin my front tires i found out that my rotors are warp.
So i have the same question as for the sway bar link,which way should i go for replacements?
and i know there is sponsors here that sell all that stuff,do you guys have any recommendations?
Sorry for the long post and thank you for the help.
1 more questions , where is a good place to order compression rods or the bushing for the compression rod?
Old Jan 9, 2012 | 07:22 PM
g35SedanSC's Avatar
bump,please help.
Old Jan 19, 2012 | 08:00 PM
Trickstyle's Avatar
If you go to the dealership bring your lube, cuz they will rape you with or without it. so i suggest buying online, I saved a lot buying OEM online.
rear end links are #4, you can search that site for the rest...
http://www.orderinfinitiparts.com/pa...iagram=3840465
btw these are for a 2003, if you have the newer ones they are like $7 more but from what i hear they are worth it!
Old Jan 20, 2012 | 10:55 AM
brandon1978's Avatar
On the end links:
If you are at stock ride height, just get OEM replacements online. If you are lowered, get aftermarket adjustable end links. I have the SPLs, but they are noisy. if I were to do it again, I'd try a different brand.
On the brakes:
You may be able to have the rotors turned. This topic has been discussed many times, so find one of the many threads here that discuss rotor options.
Old Jan 20, 2012 | 10:23 PM
g35SedanSC's Avatar
Thank you.
On the end links:
On the brakes:
Yesterday 08:00 PM
well i am having a hard decision bettng betterween going with oem or something stage 1?basicly somethi
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
atk08
Jul 30, 2015 03:12 PM
