Motordyne Sway Bars
Old Jan 9, 2012 | 01:31 PM
b_moneyy's Avatar
Motordyne Sway Bars
Hey guys, I ordered some Motordyne sway bars last week, should be receiving them later this week, and I was just wondering if anyone here has had personal experience with them? I know they will work with all the other stock parts of my suspension (end links etc.) but will I still feel the benefits of the new sway bars and more importantly will all the other parts hold up with the added stiffness? Thanks in advance!
Old Jan 10, 2012 | 02:05 PM
DEMoLITIoN's Avatar
It is a great idea to buy polyurethane sway bar bushings while you're at it. End links should not be needed unless they are currently bad.
Old Jan 12, 2012 | 11:41 PM
brandon1978's Avatar
You can try the new sway bar with the stock end links and see if they start to make noise (it will sound like a loud pop if it happens). The stiffer you set the bars, the more likely you are to have noise. A lowered car is also more likely to have noise. It would be a good idea to lube the bushings when you install the new bar. Enjoy the upgrade.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
