alightment /camber bolts question for coupe 07
Old Mar 3, 2012 | 04:38 PM
IVANISINLA's Avatar
i have alightment question .I resently took my g- zer to JUSTTIRES for an alightment they told me i need to replace 2 right cambers bolts. Front right and rear right back. I bought the oem parts from infinitionline parts but took it to the mechanic and they said i need to replace the whole part that holds the wheel. i believe is the spindle. I thought he was crazy thinking it would cheaper with him. I went back to JUSTTIRES and they said the mechanic was wrong i might need an after market camber bolts that can adjust.Are they adjustable? INFINIT PARTS ONLINE told me oem parts(CAMBER BOLTS) cannot be adjust.Someone else told me only the rear can adjust. Please help. I have 20 each wheels and car its not dropped. I dont know the width of my wheels but im planning to find out .I also would like to put 255 tires in the front and 275 rear but i fear it might rub the fender but i hear camber bolt measurement may help.need advise thank you........i attached the result of my alightment or measurement from those bolts from JUSTTIRES...please help
Attached Thumbnails alightment /camber bolts question for coupe 07-alightment-measurement.jpg
Old Mar 5, 2012 | 05:17 PM
djamps's Avatar
You need aftermarket camber arms (front AND rear) if you want to adjust the camber. You can adjust the rear TOW slightly using aftermarket tow bolts and concentric washers. But yea, the stock suspension is not really adjustable at all.
Old Mar 6, 2012 | 04:06 PM
IVANISINLA's Avatar
Ok thanx for the info needed that it makes sense .. by any chance u know which ones to go for and would it be cheaper to buy the part my self . I guess ill return the OEM bolts I got even though one dealer said only the rear is adjustable but I heard afternarket arm would be the choice ..
Old Mar 6, 2012 | 08:40 PM
djamps's Avatar
Check the vendor section. SPC's are the cheapest ones that don't suck. Don't even bother with the ichibas, they will last 5k miles tops.
Old Mar 7, 2012 | 01:21 AM
IVANISINLA's Avatar
Ok thanx
Old Mar 7, 2012 | 12:30 PM
IVANISINLA's Avatar
Lasr thing u meant left and right for rear and front camber arm correct
R350k5
Oct 1, 2015 08:41 PM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Steering & Suspension
Aug 3, 2015 02:44 PM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
hrdwirk1
Jul 14, 2015 05:46 PM
