Suspension ?
Suspension ?
I dropped my coupe on 350z pro kit springs a little while back. For some reason the drivers side sits higher than the passenger side. About 3/4 higher. I have the springs in the right way. Double checked before I put them in. And I made sure they are sitting in the perch right. I took the back springs out and swapped sides and it still sits the same. I ended up doing the spring mod on the back and took off about an 1/2" on the drivers side. Just wondering if anyone has an idea of what might be causing the difference in height? It bugs me more than anything. Wondering if I might have something bent in the suspension.
Ahh ok. I was hoping nothing was bent. It is kinda weird that the whole drivers side is higher than the passenger. The front is not as bad as the back but if it pretty much normal then ok. Thanks.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
