Will G/Z combo / revised 350z springs fit fit a 2003.0 sedan non sport WITHOUT camber
Old Jun 14, 2012 | 10:22 PM
DVG's Avatar
DVG
Cant seem to find a definitive answer
Thanks
Old Jun 15, 2012 | 06:00 AM
Blue Dream's Avatar
I drove ttrank's car solo
Yes they'll fit.
Old Jun 15, 2012 | 08:13 AM
DVG's Avatar
DVG
Yes they'll fit.
and without camber??
I just want to be sure before I pull the trigger
Old Jun 15, 2012 | 09:21 AM
Blue Dream's Avatar
Not sure what you're asking. Camber refers to the orientation of the wheels, are you asking about a camber kit that adds more adjustability of camber settings? If so there's really no way to tell if you will need one on a slight drop until you drop it and see how the tires wear. Common perception is if you drop 1" or less you don't need them. I had a different experience on sedan H Techs, didn't get either front or rear kits because of the mild drop and it still ate my tires quickly.
Old Jun 15, 2012 | 09:26 AM
DVG's Avatar
DVG
Yes, that is what I was asking
How much did the H techs drop? Did you get an alignment after, and was it in spec?
Old Jun 15, 2012 | 09:27 AM
Hossmaxima's Avatar
Yes they will fit but you will have slight camber, nothing to really worry about
Old Jun 15, 2012 | 09:29 AM
Blue Dream's Avatar
IIRC the drop was slightly less than an ince, the car was aligned twice after the springs settled, and it wouldn't get back to factory alignment specs.
Old Jun 15, 2012 | 10:20 AM
DVG's Avatar
DVG
So I guess I could just get the springs since they are fairly inexpensive, and mount them.
Ill go get an allignment, if they get alligned to factory specs, no problem, otherwise take them off and sell them.
If they are in factory specs, tires should wear properly right?
Was your experience rare? Or is it a common problem?
I just bought my first set of tires for 19" OEM rays....talk about sticker shock, so I really want them to last.
Old Jun 15, 2012 | 10:37 AM
Swivel's Avatar
Moderator
You can search it up, but I believe some people with this drop have asked their shop to align the suspension to Z specs -- you can find those out on this site or any decent shop should have them. I have the G/Z drop (see my garage for how the car sits -- nice, even wheels gaps) and while there is no camber wear specifically, my car tends to eat rear tires, though it wears them out pretty evenly. It's not due to the power or my driving habits, trust me, LOL! I think mine is a different issue, maybe toe.
Old Jun 15, 2012 | 12:28 PM
DVG's Avatar
DVG
Seems like a lot of people are having issues with it...maybe it isnt a good idea :/
Old Jun 15, 2012 | 12:40 PM
JaE35's Avatar
Moderator
G35 Sedan
z/g drop will not require a camber kit...the rear will only go down maybe a half an inch. Your searching wrong if your seeing people have issues with it, this is a very very weak drop and a waste of time IMO lol
Old Jun 15, 2012 | 01:01 PM
Blue Dream's Avatar
I think he was referring to my post.
Old Jun 15, 2012 | 01:06 PM
JaE35's Avatar
Moderator
G35 Sedan
I read that but your issue is crazy uncommon i was dropped 2 inches for a year on springs and was fine with an alignment...and i had blown shocks haha
Old Jun 15, 2012 | 02:18 PM
DVG's Avatar
DVG
swivelhips also mentioned that his suspension caused his rear tires to go quickly
Old Jun 15, 2012 | 02:44 PM
JaE35's Avatar
Moderator
G35 Sedan
You will be fine! Seriously...this is the weakest drop on planet earth lol just get an alignment after about a week
