Eibach pro kit or sportline
Old Jul 5, 2012 | 10:57 PM
JRG911's Avatar
im debating which lowering Eibach springs should i get for my G pro kit or sportline? anybody?
Old Jul 5, 2012 | 11:05 PM
Big Booty Trudy's Avatar
Sportline. I wish I woulda gone as low as you can go.
Old Jul 6, 2012 | 04:36 PM
DEMoLITIoN's Avatar
If you guys can, save for a decent set of coilovers. I had the sportline kit on stock shocks and it blew them within 6 months. The money spend on replacing springs and shocks could be spend on decent coilovers.
Old Jul 6, 2012 | 05:28 PM
Deepdiver's Avatar
I prefer the prokit. It's a little more liveable with speedbumps, dips, and transitions..
VMRWheels's Avatar
Of those two choices, I say Sportlines.
Originally Posted by henry206
how bad is the wear on tires with the sportlines do you know?
If your alignment is within spec you should be fine.
Old Jul 6, 2012 | 05:41 PM
Deepdiver's Avatar
your camber will be out of spec with both kits. You will def need a rear camber kit unless you want to chew through tires.
Old Feb 8, 2013 | 08:32 AM
Victeur-G's Avatar
For the eibach pro kit wich rear camber do i need? The Rear Camber and Toe Bolts or the Rear Camber and Control arm?
Old Feb 20, 2013 | 01:17 PM
EKris's Avatar
I went with the Pro kit for the coupe and sport coupe struts. Anyone have any idea how that would be on the Sedan's? I haven't installed them yet, but was looking to see what kind of drop and how that ride will be.
I believe my brother has sportlines on his sedan and look great and it rides pretty nicely.
Old Feb 20, 2013 | 01:32 PM
Sponger's Avatar
6MT Brembo Coupe
Agree with the Sportlines, but your alignment will be out of spec. They handle and ride very well with the Tokico blues.
Old Feb 20, 2013 | 02:31 PM
joeb1983's Avatar
G35
Prokit
I was in the same boat as you a while back. I bought a set of Tein H-techs at first because I was worried about tire wear and at the time there wasn't much info in regards to lowering with RAS (Rear Active Steer) and how low you could actually go before it effected functionality. They where able to get the alignment within spec, but honestly it was not low enough.
I then researched many springs and finally decided on Eibach's Prokit. Camber is a little out of spec, but not terribly too much. I believe spec is a little negative anyways. Ride is very comfortable and bump-stop trimming is not necessary as I hear it is with the Sportlines. Ride quality was surprisingly similar to stock. (sport tuned)
I went with KYB GR2 struts/shocks and they seem to be holding up just fine. 11k so far. Tokico HP's, AKA blues are also an excellent, cost effective strut/shock for lowering springs.
I also went with Nitto INVO's as they are uni-directional so that helps a little with wear. Wear is not bad enough for me to justify camber kits so I am also happy with that.
I think all in all my setup was around $550. A bit cheaper than coilovers, but to each is own and for my needs they weren't for me. Any lower and I wouldn't be able to make it up my driveway.
You need to ask yourself what do you plan for your car? DD, track, drift, etc... In my case I am building a fun, comfortable, street car.
Here are some pics for reference. (no spring mount mod) They did settle a tad bit more over time. I hope this helped.
Attached Thumbnails Eibach pro kit or sportline-body-kit-installed-017.jpg   Eibach pro kit or sportline-body-kit-installed-021.jpg   Eibach pro kit or sportline-body-kit-installed-031.jpg   Eibach pro kit or sportline-121.jpg   Eibach pro kit or sportline-083.jpg
Old Jan 27, 2015 | 09:33 PM
privatecorye's Avatar
What are wheel specs?
Old Jan 27, 2015 | 10:05 PM
manolobleu's Avatar
I have the sportline pro's made for the Z on my G and love it everyday I look at it. Check it out on IG manolo_is_g
Old Jan 27, 2015 | 10:14 PM
Stock struts? I'm really trying to go stock struts and no camber kits. 😥
Old Jan 27, 2015 | 10:20 PM
Eibach Sport Line or Pro Kit Springs?
I'm trying to get a nice even height on my G35 Coupe. I want a nice low but to be able to use my stock struts and only rear camber kit. I've slimmed it down to these two I will be on a set of 19" wheels. Opinions and pics would really help. Trying to figure this out. I just don't want wheel gap. Temporary until I get Coilovers.
Old Jan 28, 2015 | 05:00 AM
Frankieg35's Avatar
I have 350z pro kits and the drop is perfect, definitely noticeable drop but not to low to drive..
