Spc shims??
Old Aug 16, 2012 | 01:53 PM
Frankieg35's Avatar
Spc shims??
I know the shims are for the front but I need 2 degrees positive in the rear and was wondering if its possible to somehow use the shim in the rear??
Old Aug 16, 2012 | 04:12 PM
Frankieg35's Avatar
Spc told me to get another set of toe bolts and put them on the inner subframe where the camber arm bolts too and elongate the hole.. Does this sound right??
Old Aug 16, 2012 | 04:35 PM
JaE35's Avatar
Moderator
G35 Sedan
never thought about that...definitely a good idea
Old Aug 16, 2012 | 05:16 PM
DrewDrew's Avatar
I'd trust them. Wouldn't be the first time I've heard spc or SPL tell their G customers about improvising a little on how to get positive camber.
Old Aug 16, 2012 | 05:23 PM
Frankieg35's Avatar
He said they use the same bolts as toe bolts and to elongate the hole towards the wheels and u get 2+ degrees of camber..
Old Aug 16, 2012 | 05:45 PM
seymore4's Avatar
m56
That should work, never thought of it before. As long as you don't do much high performance driving they'll be fine. I hate those @$%@#$ toe bolts... lol
Old Aug 16, 2012 | 06:01 PM
JaE35's Avatar
Moderator
G35 Sedan
May need lockout washers for that though
Old Aug 16, 2012 | 06:03 PM
DrewDrew's Avatar
I def agree. I could see slipping being a big big issue.
Old Aug 16, 2012 | 06:29 PM
Frankieg35's Avatar
What u saying?? To put lock washers on the bolts so the camber doesn't change?? Doesn't the bolt already have something on them so they hold still??
Old Aug 16, 2012 | 06:50 PM
JaE35's Avatar
Moderator
G35 Sedan
yea but there's a lot more pressure where the camber arms are as compared to the toe bucket...theres only a washer on one side of their toe bolts, i wouldn't trust it
Old Aug 16, 2012 | 07:48 PM
Frankieg35's Avatar
Yeah that makes sense.. Do I only need one behind the head of the bolt??
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
