interchangeable struts
Old Sep 16, 2012 | 11:12 PM
TougeMonsterG35's Avatar
so i have a set of Bc coilovers but i trying to run 20x10.5 all around and i feel that the BC's are not stiff enough at my current ride hight for the Cali dips on the highways because i rub from time to time. so what i was thinking is that i would just swap out just the struts for a better ones IE stance, zeal, hks ect. insted of buying a whole new set. has anyone ever tryed this??? i think most coilover struts are the same size for the most part..... im looking into a set of swift spring hoping that will help a bit also. any info on interchangable coilover parts would be nice thx
Old Sep 18, 2012 | 01:46 PM
Wow nobody has done this before???
Old Sep 18, 2012 | 02:39 PM
VMRWheels's Avatar
I've heard of this being done before, however you'll need to confirm the actual dimensions of the shocks themselves. IE: You'll need to contact some of those manufacturers and see if their shocks are the same specs as yours.
In my opinion you should just either get stiffer springs, or you should just get different suspension altogether.
Old Sep 18, 2012 | 03:41 PM
OBsessed's Avatar
Your probably better off changing out the springs rather than the struts. Take a look at Swift springs and get whatever spring-rate you want. Pretty sure that'll have the more significant impact.
Old Sep 18, 2012 | 03:42 PM
Pbm and fortune 500 coilovers look the same size so ill start with call them and see what's up...... You think some swift springs will help????
Old Sep 18, 2012 | 05:34 PM
VMRWheels's Avatar
Honestly you can't really tell by photos, even if it's off by a couple millimeters it probably won't work.
Stiffer springs will help, yes.
Old Sep 18, 2012 | 06:09 PM
Adil_G35's Avatar
if you havent installed them yet just sell them and buy something stiffer.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
prinny
Nov 22, 2015 11:07 PM
Claudiu
Sep 26, 2015 01:04 PM
doakley92
Sep 25, 2015 12:58 PM
