knocking/creaking sound in front suspension.
Old Oct 16, 2012 | 08:10 AM
Michaelh90's Avatar
My OEM front shocks were shot already at 100k miles but i drove them couple of more thousands miles like that. i got a knocking noise everytime i step on a pothole. i though that sound was because my shocks were shot. but when i put the new ones on i still hear the knocking sound in the front. i was wkndering what is it and what should i replace? lower control? bushing? idk? any links to what i need greatly apreciate.
Old Oct 20, 2012 | 07:49 AM
Michaelh90's Avatar
Anyone?
Old Oct 20, 2012 | 12:01 PM
Adil_G35's Avatar
here are the major issues
check for:
ball joints
bushings
tie rods
endlinks
these solve most of the "clunking" issues when going over small bumps. and if you're going to replace them, dont go OEM. Upgrade them. You'll feel a major difference in handling and control.
Old Oct 20, 2012 | 12:22 PM
Michaelh90's Avatar
Thanks alot. Are tie rods same as compression rods? Im confuse on that one. And i was looking for the ball joint and all i can find is the whole lower control arm.. I would prefer to upgraded them but what do i need just the bushings ? Energy or whiteline? Or do i have to get the whole arm new?.
Old Oct 20, 2012 | 01:27 PM
Michaelh90's Avatar
I found these that have bolt joints whichi think are the compression rods.
http://www.ebay.com/itm/OEM-INFINITI...71070114224%26
And these are the lower control arms with the join bolt on already.
http://www.ebay.com/itm/130781311186...84.m1423.l2649
I would prefer upgrading instead of OEM. But i dont know what i should buy. Also im a bit short on cash since i just bought coils. Another Q' is there any harm on the car if i drive it with the broken/damage bushings . Cuz if not i could wait until next yr and buy the upgraded ones? Btw ill be doing the installation ... Only thing i cant do is remove the bushings i would have to take them to a shop and get the old out and the new ones press in...
Old Oct 20, 2012 | 07:10 PM
Adil_G35's Avatar
if your arms arent cracked or jacked up theres no need to buy the arm. just buy the ball joints if they are worn. Jack the car up and wiggle the wheels. If there is excessive play it will come down to those few items i listed earlier except the endlinks. id look at the ball joints first. the last thing you need is your entire front suspension coming apart.
Old Oct 20, 2012 | 07:13 PM
Adil_G35's Avatar
also get energy bushing set and get whiteline end links(A MUST FOR AFTERMARKET SWAYS). The OEM endlinks are known to crap out on aftermarket sways. They arent strong enough. Being dropped also puts a lot of strain on those endlinks. the 05+ have beefier end links.They are an easy install as well as the tie rods and bushings
Old Oct 20, 2012 | 08:33 PM
Michaelh90's Avatar
i was just adjusting my coils today and i didnt see anything broken.. the ball joints are not leaking grease, they all black and kind of hard but thats it. endlinks are normal not bent or anything.. the control arms are fine no cracks.. the other bushings are a bit torn most of all on the drivers side which is where i hear the squeaking noise the most.
Old Oct 20, 2012 | 08:34 PM
Michaelh90's Avatar
are these the ones i need and thats it?? what about the ball joints i cant find an upgrade for those only oem
Front KitEnergy Suspension 03-08 350Z / 03-07 Infiniti G35 Front Control Arm Bushing Set front arm kit includes the following bushings: Inner and outer front lower control arm, upper control arm, and compression rod! Red or black finish offered.
i want to change them all at the same time. thanks adil for your help..
Old Oct 29, 2012 | 08:55 AM
prelude9569's Avatar
How much does the kit in the picture cost? Will it fit a 2008 journey sedan? Looks like something I can use.
Thanks
Old Oct 29, 2012 | 09:23 AM
Michaelh90's Avatar
A vendor in the forum quote me $113 ship..
As of now to get rid of the sound i have to change
Endlinks
Control arm bushings
Compression rod bushing
Ball joints
Tie rod..
Want to change them all at the same time to save time.. I was thinking bout changing my hub bearing also. Im at 110k miles wondering what else i should change to have my G front suspension like new. =]
Old Oct 29, 2012 | 07:31 PM
thanks.
Old Oct 29, 2012 | 10:33 PM
TainoG35's Avatar
Endlinks
Ball joints
Tie rod..
Let me know how that goes and what the total is cause im having the exact same problem and its driving me INSANE
Old Nov 24, 2012 | 02:11 AM
laksjd84's Avatar
any update on this?
my front end, especially the driver side (actually i think it only happens on the driver side) creaks like a **** when going over bumps. during winter when cold, its 10 x worse. it almost sounds like its gone or lessened, when the car's been driven and hot.
it almost started to happen when i switched over from oem to stance GR+ coils.
what are some of the procedures to check and diagnose which part i will have to replace?
Old Nov 24, 2012 | 10:39 PM
Michaelh90's Avatar
I hadnt change anything cuz im not using my G that much. Plus im waiting for my tax return to buy everything at once and replace them all at once. Im also changing my bearingg/hub which is on the way. Thia is the only ball joint i have found to replace the owm knucle ball joint. http://www.ebay.com/itm/200841673170...84.m1423.l2649
Symptoms: if u use your breaks and u hear that creaking sound is cuz ur compression rod bushing and lower control arm bushing are busted.
If u hear that squaking noise when turning ur ball joints are torn.
If u go over a bump and it makes that clunk noise i believe ia the oem endlinks are broken(i have the 03 which are the worse ones)
If u hear some knock, knock, knock etc while driving. Ur hub/bearings or tie rod are broken.
