big brakes
Old Oct 22, 2012 | 07:24 PM
SDGenius's Avatar
Originally Posted by totopo
Again, unless you track your car and can get a performance oriented pad to fade from the heat, a BBK will give you basically NO improvement in braking.
It is basically some cosmetic upgrade for the vast majority of people. Same with cross drilled/slotted rotors. Basically kills your brake pads for no improvements UNLESS you regularly can get performance oriented pads to fade, ie. track conditions.
that's like saying, unless you track your car you wont get anymore performance out of a TT or SC. just because your not taking your car to the limit constantly doesn't make it any less capable. if you were referring to OEM vs OEM Brembo/Akebono then i'd agree with you, but a legit 6/4 BBK will weigh equal to or less than OEM, w/a much larger friction surface. additionally the braking feel from multiple pistons gives much better feed back. obviously tires play a HUGE role as well but speaking from a strictly "braking" component perspective, BBKs make all the difference. also panic stop distances aren't the only measure of "braking performance."
Old Oct 22, 2012 | 08:45 PM
extremetoy's Avatar
ive driven other cars with big brake kits just curious whats big in this car scene... makes a huge difference all over but yes the track is usually where you will notice the lack of fading the most. Thanks
Old Oct 22, 2012 | 09:37 PM
VMRWheels's Avatar
Originally Posted by CUxtopher
You really can go wrong with Akenbonos. Heavy, bulky, pad choice.....best oem is the Brembos by far.
OP, i have a stoptech set for sale in the classifieds>
I'm also a fan of Brembo, but from what I can see Akebonos still aren't a terrible choice for a BBK. I don't expect BBKs to be slim or small, to have as much of a pad selection, or be the most light weight.
jilljann1
Jul 21, 2020 08:12 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
DRG35R
Sep 16, 2015 05:33 AM
NJ6MT
Sep 10, 2015 08:40 AM
