G35 Aftermarket Bushing Info Thread
Old Nov 5, 2012 | 01:12 PM
DEMoLITIoN's Avatar
Front Lower Control Arm
Inner Bushing
SPL - SPL FLBI Z33
Whiteline - W52991
Outer Bushing (Shock Mount)
SPL - SPL FLBS Z33
Whiteline - W52992
Front Upper Control Arm
Whiteline - W52988
Front Compression Rod
SPL - SPL CRB Z33
Whiteline - W83389
Front Sway Bar
Energy Suspension (32mm) - 7.5126
Whiteline (32mm) - KSK059-32
Front Sway Bar End Links
SPL - SPL FE Z33
Whiteline - KLC110
Front Steering Rack
Energy Suspension - 7.10105
Rear Upper Control Arm
Whiteline - W62989
Rear R-Lower Link (Spring Bucket)
Whiteline - W62996
Rear F-Lower Link (Camber Arm)
Whiteline - W62997
Rear Radius Rod (Traction Rod)
Whiteline - W62985
Rear Knuckle
Spring Bucket
SPL (full kit) - SPL RKB Z33
Whiteline - W62535
Camber Arm
Whiteline - W62999
Traction Rod
Whiteline - W62998
Shock Mount
Whiteline - W62535
Rear Sway Bar
Energy Suspension (21mm) - 7.5127
Rear Sway Bar End Link
SPL - SPL RE Z33
Whiteline - KLC141
Rear Subframe
Energy Suspension - 7.4103
SPL - SPL SSB Z33
Whiteline - W92994
Rear Differential
Energy Suspension w/o subframe mount - 7.1119
SPL w/ subframe mount - SPL SDBS Z33
Whiteline w/o subframe mount - W93189
Whiteline w/ subframe mount - KDT911
work in progess.
Old Nov 5, 2012 | 01:19 PM
DEMoLITIoN's Avatar
work in progress reserved.
rezendvous420
May 31, 2020 01:26 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
