2006 G35x on MR Coilovers (Driver Rear sags more than Pass. Rear) HELP!
Old Nov 28, 2012 | 04:10 PM
ARB_MNY_G35x's Avatar
Okay guys so I have a 2006 g35x with 85k miles on it. The coilovers have roughly 25,000 miles on them. I drive daily about 50 miles. So my rear driver side is lower than my rear passenger side.. roughly 1/2 inch and it rubs the frame of the car when im driving around.. annoying as f***
At first I thought my driver rear coilover was blown so a buddy mechanic replaced the rear two coilovers with the factory shocks/struts but left the front two coilovers on.
This did not solve the problem, it still sags. Any suggestions on what it could be? Just replaced the rear camber arms as well as the toe arms. Any help would be appreciated!
Old Nov 29, 2012 | 02:40 PM
VMRWheels's Avatar
I would take it to a suspension/alignment specific shop and see if there are any bent components, worn bushings, etc.
Old Dec 7, 2012 | 11:11 AM
Thanks for your reply man.. Yeah i ended up taking it to a alignment shop and they told me that I either need to get thinner tires, (currently running 245/40 all around rims 19x8.5 f 19x9.5 r) or adjust the coil overs to a higher setting.
Could these issues be the reason the driver rear is lower than passenger rear?
Old Dec 7, 2012 | 01:41 PM
VMRWheels's Avatar
Your tire height shouldn't account for it having an uneven drop...
It's possible that you need to adjust it slightly between sides though.
Old Jan 29, 2013 | 02:34 PM
Is there a way to adjust only the driver rear and not configure the right rear? or do they higher and lower simultaneously?
I just had the car raised on all 4 corners and the left rear is still sagging. could it be my bushings? what other suspension components could be the cause?
Old Feb 3, 2013 | 09:25 PM
FlyingLumpia's Avatar
MR coilovers?
Old Feb 4, 2013 | 06:47 PM
Originally Posted by FlyingLumpia
MR coilovers?
Yeah Megan racing coilovers.. Whatever the problem is its causing my rear driver brake and rotor to wear quickly.. Any ideas?
nickmcc123
Lights
Oct 7, 2017 12:18 AM
kinetek
Aug 3, 2015 04:25 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
