Help! front driver side rattling noise
Old Jan 10, 2013 | 06:35 PM
dexthurr21's Avatar
I have a 2006 G35 Coupe. I'm hearing a rattling sound in the front driver side whenever I drive; it only stops when I hit the brakes.
I have no clue where the sound is coming from. Had anyone experience this before? Any ideas? Thanks
Old Jan 12, 2013 | 12:47 AM
JosansG35's Avatar
That sounds like my car! I did some research, and it will most likely be your tie rod.
But first, check to make sure all of your bushings are still in working condition(not torn) as well as your endlinks. If all of that is fine, it's most likely your tie rod.
Old Jan 12, 2013 | 01:24 AM
dexthurr21's Avatar
i know, but i was thinking it's the lower ball joint. there's a picture below.
Old Jan 12, 2013 | 07:43 PM
JosansG35's Avatar
Yea it looks fvcked up! Replace that first. If that doesn't fix it then move on to the next one.
Old Jan 24, 2013 | 04:45 PM
dexthurr21's Avatar
The problem was my wheel bearing btw.
rezendvous420
May 31, 2020 01:26 PM
mbe093
Lights
Oct 2, 2016 11:09 PM
R350k5
Oct 1, 2015 08:41 PM
kinetek
Aug 3, 2015 04:25 PM
attarday
Jul 15, 2015 04:03 PM
