Camber Kit
Old Jan 15, 2013 | 06:28 PM
Marcum6's Avatar
Camber Kit
I put a set of Eibach Proline springs on my 2004 G35 coupe. I called Eibach prior to buying the springs and they said I could get within -.5 without adding any additional suspension parts. They were wrong. It just came back from the alignment shop, the rear out at least -1.5 maybe even 2.0 and the front is out over 1.0. I'm ordering the rear camber kit from Eibach. Is there a cheaper alternative to correcting the front other than new upper control arms?
Also I want to put 19x8.5" rims all the way around. What offset should I look for? I'm thinking of either going with enkei raijin or varrstoen ES1 or ES4's. Does anyone have either of those wheels on a lowered G?
Old Jan 15, 2013 | 09:00 PM
Algy's Avatar
None that I know of. If you want to get it back into spec, most likely its going to have to be a new upper control arm.
You have a variety of companies to choose from. From there you can find different price ranges.
Hope that helps.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
