s-techs unever FRONTS ONLY
Old Mar 10, 2013 | 03:09 AM
g06driver's Avatar
So i installed my z s-techs on my g a little over a month ago as well as did the springmount mod becuase i knew the s techs were notorious for an uneven drop front compared to backs. but today i noticed that my drivers side front sits about almost a half an inch lower than the pass front. any ideas what it could be? the backs seem even with each other or at least close.
Old Mar 10, 2013 | 08:49 PM
vegaszx10's Avatar
When the spring have settled most cars are usually lower on the driver side cause of consistent weight there. You don't always have weight in the passenger side.. Half an inch is not bad at all, mine is the same, and no I'm not calling you fat. LOL
Old Mar 10, 2013 | 09:11 PM
g06driver's Avatar
haha ok thanks.
Old Mar 14, 2013 | 05:26 PM
DomeP1ece's Avatar
Check the upper mounts, the rubber sometimes falls out of the way after its been cut because it loses strength. Cutting isn't always the best option for getting that extra 1/2" of drop. you are changing parts that see constant abuse.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
miata007
Aug 17, 2015 04:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
