Swaybar Endlink Bushing
Old Mar 12, 2013 | 02:26 PM
riley9's Avatar
I need to replace front swaybar endlinks and endlink bushings on my 2005 G35X. I am going to get the Moog endlinks but I cannot locate endlink bushings. Are the endlink bushings available separately? Would someone provide a manufacturer/part number?
Old Mar 12, 2013 | 02:34 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
kind of perplexed from this question,
there are no end link bushings seperately, at least from OEM point of view,
I can get the End Links/w bushings
2WD - 73 shipped
AWD - 81 shipped
Old Mar 12, 2013 | 02:35 PM
PREMIUM SPONSOR
Unless you are referring to the Sway Bar bushings....
Old Mar 12, 2013 | 03:00 PM
riley9's Avatar
The bushing (endlink mount?) that bolts to the lower control arm.
Old Mar 12, 2013 | 03:02 PM
riley9's Avatar
Not the swaybar bushings. That is what I keep getting when I search.
Old Mar 12, 2013 | 04:26 PM
PREMIUM SPONSOR
From the pics I see when I google Sway Bar End Links, looks like they come with it, I don't see any way they would sell them without it....
Old Mar 13, 2013 | 09:59 AM
riley9's Avatar
This is the part. I have not seen any endlinks that include it. The endlink has a bolt that connects to the swaybar. Unlike most endlinks there is no bolt on the 2005 X endlink for the connection to the control arm.
Attached Thumbnails Swaybar Endlink Bushing-diagram.jpg   Swaybar Endlink Bushing-endlink.jpg
Old Mar 13, 2013 | 10:14 AM
PREMIUM SPONSOR
the only way to get that bushing at least from OEM stanpoint, is to get the lower control arm,
Old Mar 14, 2013 | 06:59 PM
DomeP1ece's Avatar
i believe whiteline makes that bushing. you are refering to the one in the lower control arm that the endlink bolts through?
Old Apr 24, 2013 | 12:19 PM
keithk831's Avatar
Bringing this back to life since I might need to replace the same bushing.
Were you able to figure out what you needed?
Old Aug 21, 2013 | 10:59 PM
yosip1115's Avatar
Nobody?
I'm about to start fabbing up my own set...
Old Aug 21, 2013 | 11:50 PM
keithk831's Avatar
I ended up finding the part a few months back. It's an Infiniti-only part. It's called a stabilizer connecting rod.
http://www.infinitipartsusa.com/Item...546-124037.htm
I actually got it from Rich@Grubbs. Part number is 54618-AQ305
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
