Help emusa speedy racer Coilovers install
Old Apr 22, 2013 | 08:12 AM
jowca123's Avatar
Yesterday I went to install my speedy racer emusa Coilovers and the fronts were a breeze and ha them done in and hour and half and we got to the rears and where complealty lost it seemed like the company sent the wrong rears but they are the correct rear coils. They don not have a aftermarket shorter spring the stock spring really doesn't fit at all and I'm just lost and was looking for some insight any info or pictures would be greatly appreciated I know there cheap coils but I'm 17 and just wanted them on so don't criticize thanks hope to hear from anyone here's the link to the coils I bought http://www.speedyracer.com/suspensio...-Damper-GREEN-
Old Apr 22, 2013 | 08:38 AM
OBsessed's Avatar
So what did the rears come with? Is it just a strut? Is it a strut with a spring on it like the fronts? Any pics you can post would be helpful.
Old Apr 22, 2013 | 08:46 AM
jowca123's Avatar
Rear coils
The rears came with the two struts but the struts have spring around them just as the fronts do and also came with two circular pieces of metal that should fit on a spring but they did not supply a spring only the stock spring to use if you look at the link it will show you what I'm talking about thanks
Old Apr 22, 2013 | 11:01 AM
OBsessed's Avatar
Ok, now I'm following. The rear suspension would be considered a "true style" rear as it's got the strut and coil over the strut (coilover) and not a separate rear spring. Why they'd also include the "adjustable" rear spring mount I don't know. Give them a call and see what they were thinking. Normally on a setup like this you wouldn't use the OEM style rear spring at all.
Old Apr 22, 2013 | 11:07 AM
jowca123's Avatar
Ok that makes sense but why would they include those four metal circle things that go on the springs ?
Old Apr 22, 2013 | 11:09 AM
jowca123's Avatar
Ok now I see what you said thank you much appreciated
zoop425
Mar 29, 2016 05:51 PM
itztwinki3
Oct 5, 2015 11:29 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
