Small Questions Thread: Brakes and Suspension
Old Jan 15, 2014 | 04:46 PM
  #61
DEMoLITIoN's Avatar
Buuump
Old Jan 16, 2014 | 11:37 AM
  #62
gq916's Avatar
Originally Posted by LoSt180
Sedans with sports package have the same shocks as the base model coupe. KYB makes good OEM quality parts, and can be purchased at most auto parts stores.
KYB only has one part number for sedans and base model coupes, so you should be fine with those (free upgrade for the non-sport owners). The other part number from KYB is for Coupes w/ sport package and for 350Z's.
thanks! i wonder if the sport coupe ones would fit on my car???
Old Jan 16, 2014 | 11:56 AM
  #63
Blue Dream's Avatar
I drove ttrank's car solo
Yes they'll fit.
Old Jan 16, 2014 | 11:58 AM
  #64
LoSt180's Avatar
They'll physically fit, but are designed for the firmer spring rates found in the 350Z/sport coupes. The sedan/base coupe have softer springs.
You might have to search around to see if it's a good or bad thing, because I'm not sure. I just know there's a relation between spring rates and shock design. And for some reason is sticks in my head that using 'firm' shocks on soft springs causes them to wear out prematurely.
Old Jan 16, 2014 | 05:26 PM
  #65
gq916's Avatar
do you know what the spring rates are for sedan and coupe? I know my springs are stiffer than stock, i have tanabe NF210..i'll have to see what the spring rate is..
but you're sure they'll fit on the sedan?
Old Jan 16, 2014 | 06:21 PM
  #66
bransyn24's Avatar
what coils to get?
im looking to get coils for my 03 G coupe but im not trying to spend over 800$.
are there any below 800$ that are worth getting?
Old Jan 16, 2014 | 07:07 PM
  #67
thegreatkwijibo's Avatar
Old Jan 17, 2014 | 10:52 AM
  #68
Blue Dream's Avatar
Simple answer is no.
Old Jan 17, 2014 | 12:05 PM
  #69
LoSt180's Avatar
There's a sticky that answers your spring rate question: https://g35driver.com/forums/brakes-...w-updates.html
Old Jan 17, 2014 | 12:44 PM
  #70
Frankieg35's Avatar
U can get a nice set of used coils for $800..
Old Jan 17, 2014 | 12:53 PM
  #71
gq916's Avatar
thanks! this explains everything..
god dammit my tanabe springs are a little softer than sport oem springs. Oh well, its still stiff and i dont take my car to the track (road coarse).
Old Jan 17, 2014 | 01:24 PM
  #72
LoSt180's Avatar
That's the main reason I still have 350Z springs. Aftermarket ones are all soft, or progressive. Waiting on chance for coil overs.
Old Jan 21, 2014 | 04:44 AM
  #73
Chase Carver's Avatar
What else do I need to get for sway bar install
Hey guys, I tried using the search but it didn't help to much and I don't want to miss anything.
I just ordered hotchkis front and rear sway bars for my 04 G35 coupe. Suspension wise my car is bone stock. It comes with greasable bushings and brackets. What else do I need/should I get to make the install as good as possible.
Thanks guys!
Old Jan 21, 2014 | 05:02 AM
  #74
.cakestar's Avatar
get some adjustable endlinks
Old Jan 21, 2014 | 06:40 AM
  #75
LoSt180's Avatar
Endlinks are nice to have, but you don't need them unless yours are bad or you plan on dropping it in the near future.
