front wheel camber wear help!
Old May 2, 2013 | 03:19 AM
drew89's Avatar
So my g35 is dropped 2 inches on somewhat new suspension with aggressive wheels. camber tire wear runs evenly except for my front wheel on the driver side. the front driver wheel's camber wear is worst than all the others and the groove on the front driver's side is like a bumpy groove. i hear squeaking from time to time especially if i turn my wheel to the left. any ideas guys? bearings, bushings causing the problem? thanks y'all
Old May 2, 2013 | 08:25 AM
Blue Dream's Avatar
I drove ttrank's car solo
My guess is you have a bad wheel bearing on the driver's side and that corner won't hold an alignment. Good way to check for a bad bearing is to jack up that corner and grab the tire left and right and try to move it side to side. If there's any play at all the bearing's shot. The bumpy groove is most likely feathering caused by out of spec toe.
Cajuncowboy
Jun 21, 2021 09:47 AM
Xfactor
Dec 1, 2019 12:52 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
rping
Jul 26, 2015 09:53 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
