New Rotors Don't Fit
Old May 6, 2013 | 01:04 PM
whoozyadaddy7's Avatar
Hey everyone,
I purchased a D2 BBK locally a little while ago, and went to install them and I am having some issues. This is my first time I have installed brakes, however I was working on it with a family member who is a certified mechanic so I had some professional guidance.
The issue: The rotors didn't fit. They are 2 piece rotors. The rotor itself seemed to be the right size: 330mm by 32mm but we guessed that the hub portion (rotor hat?) that was bolted onto the rotor was wrong. Although it was strange because the hub bore and bolt pattern was correct because it slid right on. However once we fully tightened the rotor it wouldn't even budge because it was hitting the lower portion of the spindle on a knuckle there. Initially we just figured the issue was the dust shield but we hacked that completely off, then fully tightened the rotor and it was stuck. We considered shaving the knuckle but since the rotor was knocking so bad we didn't even bother.
Does anyone know if we were doing something wrong or if the rotors were simply the wrong size? Any help would be appreciated.
Sorry, I forgot to take pictures. Hopefully this explanation will suffice. Thanks in advance.
Old May 6, 2013 | 04:20 PM
shyun1250's Avatar
Pictures would be better.
So you took out all the dust shields?
Is this for the front and rear or just the fronts?
Old May 6, 2013 | 04:25 PM
SDGenius's Avatar
maybe you mounted the disc to the hat wrong
Old May 6, 2013 | 04:27 PM
gary c's Avatar
You're in luck by ordering them locally, they don't fit....take em back! Someone transposed a number wrong and gave you the wrong rotors, just get the right ones....Gary
Old May 7, 2013 | 07:53 PM
This is just for the fronts. All dust shields were removed.
They came to me mounted, so I am thinking maybe they were just the wrong size ;/
I am going to have to do that. Unfortunately they require me to prove they don't fit so I just need to find time to swap things again to take some pictures.
Thanks for the comments everyone.
EnCr1pt3d
Jul 8, 2019 02:48 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
miata007
Aug 17, 2015 04:36 PM
sahizzle110
Jul 29, 2015 11:36 AM
RedBaronK
Jul 27, 2015 03:19 PM
