Labor to Replace Brake Booster
How much should I be paying for the labor to replace a brake booster? Using shop across the street (bought parts from eBay)...
Is it a fast and easy job?
Thanks!
Thanks!
It's a simple job, but it's bulky to remove so you need to remove master cylinder and the hard brake lines to have space. Then you are supposed to bleed all the brake lines since you will probably get air in the system. I'd guess 1 hour for booster + brake bleeding.
I did it and then realized the problem was something completely different --- you sure you need a new booster?
