Akebono Brake Kit installtion question
Old Sep 10, 2013 | 10:38 AM
tnmt_donkey's Avatar
Brakes Akebono Brake Kit installtion question
I just had my a full set of Akebono brake kit installed on my 06 coupe last month.
And I went to Infiniti this morning for oil change. The mechanic said the calipers were installed on the wrong side. The bleeding ports should be pointing upward. (Now they are pointing downward.)
Is the mechanic right?
What is the difference between the port directions?
Thank you for your opinion!
Old Sep 10, 2013 | 11:02 AM
WhosUrBuddiee's Avatar
Yes mechanic is right.
Functionally they will work the same since pistons are same size. Only real difference is you cant bleed them properly with port pointing downward. You probably have a slightly spongy feel in your pedal.
Thankfully it is easy to swap them.
Old Sep 10, 2013 | 11:09 AM
You're probably right. The day of installation, my mechanic spent quite some time on bleeding. And the padel feel is not as strong as I expected.
My mechanic is agreed to change them this weekend. I just hope everything would go quick and well.
Old Sep 10, 2013 | 12:01 PM
Blue Dream's Avatar
I drove ttrank's car solo
The real question is why do you go to the dealer for an oil change? And tell me you didn't let them wash it for you as well.........
Old Sep 10, 2013 | 03:16 PM
Herbbie Hablib's Avatar
free cookies, and usually the chick at the desk is hot.
Old Sep 10, 2013 | 05:56 PM
Yes, I did let them wash my car.
And they peeled off paint off my hood.
Old Sep 18, 2013 | 12:51 PM
RuKiSBoY's Avatar
Damn did you make a complaint?
jsimonk
Dec 22, 2023 03:49 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
