Inner cam bolt spinning help please
Old Sep 13, 2013 | 08:16 PM
guitarrocker98's Avatar
What do you do if these inner cam bolts are spinning? One is spinning, therefore I can't get out the camber arm. Help. The bolt in red. It is spinning. No way to get behind it at all.
Old Sep 16, 2013 | 02:15 AM
Bumpy bump
Old Sep 16, 2013 | 03:51 AM
Blue Dream's Avatar
I drove ttrank's car solo
Are you talking about the nuts on the swaybar bracket you have circled in red? Those should come right off as the bolts are welded to the frame. If you're talking about the bolt in blue, you need to take off the swaybar to get it out.
Old Sep 16, 2013 | 11:20 AM
DEMoLITIoN's Avatar
You will need to buy an eccentric lockout kit.
Old Sep 16, 2013 | 11:59 AM
Yes I'm talking about the sway bar bracket bolt. It's not welded in anymore.
Old Sep 16, 2013 | 12:09 PM
redpearl99's Avatar
if your sway bar bolt is just spinning then you prob just stripped the bolt/nut
Old Sep 16, 2013 | 12:49 PM
It's not stripped. So what it is, is the other side is suppose to be welded to the frame. The previous owner installed the sway bar. Most likely he over torqued it. I'm just seeing if anyone has any ideas. I have a few people who say cut a line in it with a dremel. Them hold it with a screw driver and get it out. But my issue will be to get it back in.
Old Oct 6, 2013 | 06:21 PM
Opposite side bolts are stripped. Help getting them off. Please.
Old Oct 6, 2013 | 06:22 PM
It broke sockets trying to get them off, bought a new 17mm socket and it stripped the bolt. Any ideas on how to get it off. Both of them are essentially stuck on.
Old Oct 7, 2013 | 02:23 AM
Anyone on the rounded nuts?
Old Oct 7, 2013 | 08:40 AM
Blue Dream's Avatar
Now I'm really confused, are the other side bolts stripped or the nuts? You've mentioned both. If it's the nuts use these: http://www.sears.com/hanson-5-piece-...1&blockType=G1
Old Oct 7, 2013 | 01:15 PM
It's both. On the passenger side it was spinning. I had to hack it off. Noting I could do worked. Then on the drivers side both nuts are rounded. I'll buy that lockout kit. Someone ran into this on 350z forums. Though they never posted if it worked.
Old Oct 8, 2013 | 03:02 PM
I think I need a deep socket. I can't seem to find anyone who sells deep socket ones.
Old Oct 9, 2013 | 06:37 AM
Blue Dream's Avatar
Did you open my link? Sears carries them but they're not cheap.
Old Oct 13, 2013 | 01:48 AM
Got ya. I did open up the link, but I was on the I pad and it didn't exactly work.
