Vibration, not a balance issue
Old Oct 5, 2013 | 11:23 AM
Jadazio's Avatar
I have a severe vibration over 65 mph that comes and goes while staying at the same speed. Car has no bent rims or rotors, they are all new. Also replaced a hub that may have had a flat spot in the bearings. I would prefer not to drop it off at the dealer and ask them to figure it out.$$$$
Old Oct 9, 2013 | 01:00 PM
Bassman's Avatar
Are you sure your tires are perfectly round. I got a set of Firestones one time from Tire rack that were not round and had the same symtoms.
Old Oct 9, 2013 | 01:37 PM
LoSt180's Avatar
Double check the balancing, maybe even try a shop that does the roadforce balancing.
Is the vibration in the steering wheel or does it feel like the whole car is shaking (ie from the back)? I had a crazy intermittent vibration at highway speeds as well and it turned out to be a blown rear differential bushing. They leak goo when they go bad, so it should be pretty obvious if you look under the car.
obender66
18 Inch
Mar 13, 2016 12:20 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
j_mullet
Aug 26, 2015 10:49 PM
Frostbite91
Aug 20, 2015 07:20 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
