Thumping noise
Old Oct 30, 2013 | 10:28 AM
luispequeno's Avatar
Thumping noise
Hey guys I hope I'm in the right section. I have a 2007 coupe with almost 72k miles. My car has the typical road noise but I also have a weird thumping noise on my driver floor board when going around 70-85mph.
When I'm on the highway and have a slight left curve, I steer a little to the left and the noise gets Louder and I start feeling the thump on my floor board a little louder.
Is this the compression rods I keep reading about? I lifted the car and checked for play on the rack and pinion, tie rods, a-arms, even the drive shaft. And I see nothing obvious.
Please help. I do a lot of highway driving and the noise is driving me insane!
Old Oct 30, 2013 | 12:44 PM
DEMoLITIoN's Avatar
Blown shock /end thread
Old Oct 30, 2013 | 03:57 PM
How can I confirm? I see no oil leaks out of them? Also the car only has 72k with stock suspension...
Old Oct 30, 2013 | 07:52 PM
Urbanengineer's Avatar
Independent shop!
Old Oct 30, 2013 | 09:29 PM
AuAltima3.5's Avatar
Independent shop!
Yes, if you are not comfortable troubleshooting yourself this is a good option.
If you can do it yourself or with a friend, jack up the front end (both sides) and get a prybar. You should be able to check for play using the prybar for leverage. The FSM outlines where to pry.
Also rock the wheel side to side and up down to check for a bad bearing.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
