Adjustable Suspension Thread
Old Nov 25, 2013 | 01:41 PM
DEMoLITIoN's Avatar
I'm making this thread as a go to for anything regarding adjustable suspension. Discussion/ pictures/ anything suspension related is welcome. It is a work in progress. Feel free to message me a brand you would like to see on here. This should cut down threads on these types of questions.
I will not add companies that have copied a design.
Adjustable Upper Links:
Cusco
Adjustability: +1-1.25 degrees
Kinetix
Adjustability: -/+ 1.5 degrees
SPC
Adjustability:
Camber: -/+ 2.5 degrees
Caster: -/+ 1.0 degrees
SPL
Adjustability:
Camber: -2.5 - +1.0 degrees
Stillen
Adjustability: -2.5 - +0.25 degrees
Adjustable End Links:
Powergrid Endloinks
SPL
Whiteline
Adjustable Rear Camber Links:
Cusco
Adjustability: -/+ 12mm
Kinetix
Adjustability: Full Range
Powered By Max
SPC
Adjustability: -/+ 4.0 degrees
SPL
Adjustablitlity: -/+ 10.0 degrees
Stance
Stillen
Adjustable Traction Links:
Cusco
Kinetix
Powered By Max
SPL
Stance
Adjustable Toe Rods:
Powered By Max:
~ lifetime manufacturers defect warranty
~ All steel tubular construction
~ Teflon lined spherical bearings
~ Forged Clamping rod end receiver
~ Forged Clamping double threaded adjuster makes double sure your settings never come loose
~ Super long adjuster threads have the most thread overlap and more adjustability than anything on the market
~ Adjuster away from the subframe, on the knuckle side for easier adjustments
~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion
~ Laser cut reinforced mounting bracket
~ Copper and Gold plated finish
Adjustable Outer Tie Rods:
Steering Angle Kits:
Powered By Max:
DEMoLITIoN's Avatar
reserved
Old Feb 4, 2014 | 03:53 PM
DEMoLITIoN's Avatar
does anyone wan't to post pictures of their setup?
Old Feb 4, 2014 | 04:04 PM
JaE35's Avatar
Moderator
G35 Sedan
Nice thread, didn't know the cusco's did positive..noted
Old Feb 4, 2014 | 04:12 PM
Frankieg35's Avatar
What is the benefit of adjustable traction links??
Old Feb 4, 2014 | 04:16 PM
JaE35's Avatar
Moderator
G35 Sedan
Gives you some added toe adjust-ability
Old Feb 4, 2014 | 04:20 PM
Frankieg35's Avatar
Oh, are they the same as toe arms??
Old Feb 6, 2014 | 04:42 PM
DEMoLITIoN's Avatar
No, "Toe Arms" replace the spring bucket. They can only be used when you have True Style coilovers.
Old Feb 6, 2014 | 04:48 PM
Frankieg35's Avatar
Oh, yeah I knew about the toe arms.. Im thinking of getting some.. I have empty spring buckets now..
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
nosam1g
Aug 22, 2015 11:58 PM
linedr89
Aug 17, 2015 05:11 PM
jimNC
Jul 25, 2015 05:47 AM
Carlos_G358696
Jul 18, 2015 03:22 PM
