Alignment Specs Question
Old Dec 9, 2013 | 10:55 PM
Subiedrewbie's Avatar
This may be an easy one for some of you. My 2004 rwd sedan is on tein h techs. Rear alignment is in spec. Front alignment is -1.4deg camber. I'm back on 18x8 stock wheels that I can rotate. Will I be running through tires even if I rotate every 5k miles? Seems crazy to spend $380 on spc kit plus another alignment. Thanks
Old Dec 9, 2013 | 11:00 PM
Urbanengineer's Avatar
There are many other things that play into handling characteristics other then camber, including toe, etc.
If that isn't your focus, you may notice a little feathering going on with your tires now that your camber is approaching the spec maximum.
FMI, contact forum member Toretto, he knows too much about tires and alignment setups.
Old Dec 9, 2013 | 11:06 PM
Awesome. Thanks. Yeah I used Bear alignment in Corona and they were not digital. Probably should go to corner3garage this weekend to get it checked out.
Old Dec 10, 2013 | 12:16 AM
totopo's Avatar
I thought people generally feel that manual alignment is superior to digital alignment.
It depends a lot on your driving style and possibly bushings. If you autox/track a lot you probably can still wear out your outside first at -1.4 camber. If you daily drive your car around town you can probably wear out your inside first.
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 18, 2015 12:33 PM
