Rear driver side wheel - squealing - not when braking
Old Jan 3, 2014 | 11:44 AM
acteg's Avatar
I've had my G for 8 years now. Been a pretty good car except for the common problems (I've had all of them).
Yesterday I developed a metallic (metal on metal) sounding squeal from the driver side rear wheel. Naturally, I jacked up the rear end, and put her in neutral while I slowly turned the wheel and was able to replicate the squealing. So, next I removed the brake pads, thinking it could possible be a wear indicator or some defect in the pads. I began rotating the rotor and the squealing persists (even though there are no brake pads in the caliper) so I know it is not brake related.
My next logical step would be to remove the rotor, and determine if it is some sort of defect in the rotor or if something is possibly trapped between the rotor and the dust shield, causing the squealing.
Any ideas?
Old Jan 3, 2014 | 03:25 PM
Urbanengineer's Avatar
Is it like a tsk tsk tsk? That would be your e brake dragging.
Old Jan 3, 2014 | 06:23 PM
saywat?'s Avatar
brakes don't need to be applied for the pad indicator to make the scraping sound
Old Jan 4, 2014 | 01:24 AM
coffeysm's Avatar
Maybe a bent dust shield?
kinetek
Aug 3, 2015 04:25 PM
teamghost
Jul 28, 2015 04:52 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
vstypicals
Jul 20, 2015 10:55 PM
